Currently reading:
New underwater cable
Discuss New underwater cable in the UK Electrical Forum area at ElectriciansForums.net
No,those numbers stack up....it's 14 kW for one property,which is about right with LED's and hydrogen heating.....and 14 properties with the power off ?
Hunger Games here we come ?
Yes I believe that's the figure the DNOs use as an average.
I did see it published once but haven't managed to find it again.
I guess it would be a long-term average equivalent to around £144/month cost.
But it just seems very wrong to claim it covers so many houses as at many times folks will be far over that, cooking, EV charge, etc.
I'm sure the figure used for cable cals for the DNO is around 4amps per house.
So for a group of 25 houses all fed from the same feeder and source the cable would only need to support a load of 100amps.
The DNOs have got years of historic data on actual loads on thier systems.
Even in a group of 25 I bet you'd be lucky to find 1 E.V let alone on charge as well.
Of find more than 1 electric shower in use at exactly the same time
Right, found it, must be because I've had Shredded Wheat for Breakfast.
The best search term is ADMD, After Diversity Max Demand.
This is from Western Power, used for the design of networks for new housing estates;
And this is a study by Strathclyde Uni on the effects of going all electric.
They were not convinced by the industry published ADMD figures so have used higher ones as a base.
It's surprising how far the existing network can going before it starts to get strained, although it's all averages so some parts of the Network will have reached failure point earlier whilst others, possible older ones where industrial load has been removed, will cope with an even higher demand.
I guess that is it, enough properties ad they average out to a low value. Still, it would also be interesting to see how much it varies by day, as I have in my memory a value closer to 5kW/home allowed for sizing substations (eg. 500kVA = 100 homes or thereabouts, not 500 homes).
And going back to the original statement, that would be group of 1.4m homes of average size in an area of average network cabling and equipment.
Not any random 1.4 m homes.
Won't be much good if Norway gets a prolonged dry spell tho.?
They'll be after our Wind generation then.
Reply to New underwater cable in the UK Electrical Forum area at ElectriciansForums.net
