Discuss New underwater cable in the UK Electrical Forum area at ElectriciansForums.net
No,those numbers stack up....it's 14 kW for one property,which is about right with LED's and hydrogen heating.....and 14 properties with the power off ?
Hunger Games here we come ?
how many Transits will the pikeys need to nick all that cable?
Yes I believe that's the figure the DNOs use as an average.
I did see it published once but haven't managed to find it again.
I guess it would be a long-term average equivalent to around ÂŁ144/month cost.
But it just seems very wrong to claim it covers so many houses as at many times folks will be far over that, cooking, EV charge, etc.
I'm sure the figure used for cable cals for the DNO is around 4amps per house.
So for a group of 25 houses all fed from the same feeder and source the cable would only need to support a load of 100amps.
The DNOs have got years of historic data on actual loads on thier systems.
Even in a group of 25 I bet you'd be lucky to find 1 E.V let alone on charge as well.
Of find more than 1 electric shower in use at exactly the same time
Right, found it, must be because I've had Shredded Wheat for Breakfast.
The best search term is ADMD, After Diversity Max Demand.
This is from Western Power, used for the design of networks for new housing estates;
And this is a study by Strathclyde Uni on the effects of going all electric.
They were not convinced by the industry published ADMD figures so have used higher ones as a base.
It's surprising how far the existing network can going before it starts to get strained, although it's all averages so some parts of the Network will have reached failure point earlier whilst others, possible older ones where industrial load has been removed, will cope with an even higher demand.
Reply to New underwater cable in the UK Electrical Forum area at ElectriciansForums.net
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Introducing the NEW IP Rated SWITCHLINK System! This system provides a quick and easy solution to a light switch when cabling is tricky, expensive...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
CheckaTrade | MyBuilder | RatedPeople | TrustaTrader etc - Who's with what and why? Thought I'd start a poll off to see if we can see who's with...
34K
M
Hi All. I am new to this forum. I am a sparky whom has been largely out of the trade for 20 years, with the exception of the odd little job for...
