- Reaction score
- 8
This is a really basic question but I’m just wanted to make sure I have installed a security light correctly and safety. Basically I installed a security light today at my friends house. There was a spur in the bedroom that was no longer in use but was wired in with the ring main, there was no load as it use to be an old emersion heater that got ripped out. I drilled straight through the spur through to the outside then fed 0.75mm pond flex for the security light as the load. I then siliconed the holes. I changed the spurs fuse from a 13a fuse to a 3a fuse. After closely looking at the security light I realised that the light is already flexed up into the light fitting. The cable is far to short to reach through the brick wall into the spur and weirdly I can’t open the light fitting up. Is it ok for me to get an waterproof junction box and put both the pre wired flex into it with my 0.75mm pond flex? My friend said he would be fine with it this way as it would save him money buying an other light but would this be ok? Just wanting to make sure as I haven’t really got much experience with security lights.
