T
ta-electrical
Hi, just need to have a question answered;
I am putting in a split board consumer unit in the house and supplying a SWA 6mm cable to an outside shed - supplying a 30mm RCD board which will have a ring main on and a lighting circuit. The SWA cable will be buried all the way through the garden atleast a foot down.
Question : The SWA cable in the house on the main consumer unit should it have a 32amp MCB or a 32amp RCBO - note that it will not be on the main split board itself so, a fault would not trip supply to the shed.
Thanks.
Thanks.
