Currently reading:
Terminating SWA with Wylex REC Supply Isolators
Discuss Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
I need to terminate 16mm SWA 2 core cable in Wylex REC Supply Isolators. Going to be using armour for earth. Whats the best thing to do with the earth. I have 12 of these to install. The only idea I have is to terminate armour on steel trunking then run 2 cores into Wylex REC Supply Isolators. Lastly connect earth back to intake. I'm sure there is a better way, I dont want to use steel trunking unless I have to?
See link below for Wylex REC Supply Isolators
http://www.tlc-direct.co.uk/Technical/DataSheets/Wylex/WYREC2.pdf
How about you post a picture of what you have now and then after your sparky has finished??
No worries, I'll put a picture up later this week as it is today. Then when it's all done I'll post an update. Although the update won't be for a few months as I am still waiting for UK Power networks to do thier survey, then we have to wait for EDF. But sparky is going to progress in the mean time.
I've managed to get some photo's, I've got one of the main intake, another of a further electrical cupboard and a sample of the current installation in each studio.
You can see it's in desperate need of upgrading and bringing up to current legislation.
That would be a nice job to do, I'd quite enjoy it.
The Ryefield needs upgrading as its only a 100a unit. No way man enough for 12 flats!.
Btw you really shouldn't have the cover off it!
I'm also not sure if you are going to have room for 12 meters and 12 switch fuses
I think there should be 6 supplies, but one of the meters is missing. Not sure what happend to it!
UKPN said he wants 3M, we're gonna have to either be creative with the space or move the intake cupboard, but that will be a problem. He also wants 1M behind the cupboard in case of electric shock, so you don't fall back onto the equipment. We have lots of height, but width is the problem. I'm hoping we can stagger the height of the meters to get them closer. Also maybe 8 above conduit and 4 below alongside new Ryefield, anyone got a shoehorn!
I'll send an update with his thoughts, he visits next Thursday.
UK Power Networks have been. I'm still waiting on final dimensions for cut-out, but this looks like what the design might look like. I need to ring EDF to confirm minimum width allowed for meters. We are okay for height with meters, but fusedswitches are getting high.
Quote was £5,009 which was inline with my expectations, so happy with this. He is going to put 100A fuse to each flat/bedsit.
Any thoughts on layout?
Dimensions in bottom corner are origional cupboard size. I'm restricted by width, but not height with cupboard.
Slight revision, Cut-Out is slightly bigger, I've also set meters directly on trunking to reduce overall height and lift lower switchfuses.
UKPower Networks and EDF have both approved design, but I would be greatful of any further suggestions.
It's a big job, electrician is doing the work. This is just a small part of the job. The SWA runs off in a straight line, so no problem with SWA.
Well spotted, the cupboard is 90mm short, but I can easily make it higher, it's width that I can't do anything about.
I'll be making adjustment to cupboard, putting mounting board in and mounting Wylex on the wall, then DNO fitting Cut-Out, EDF fitting new meters and sparky connecting back to CU's.
UK Power Networks have agreed Cut-Out 100mm from floor is okay.
Reply to Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
