- Reaction score
- 3,768
there around £30 new, ill get round to selling it at some pointWhy don't you sell it?
Discuss Test kit recommendations please in the Electrical Tools and Products area at ElectriciansForums.net
i agree with the flukes but i dont trust the t90 ive got a brand new one in the garage thats never been used.
i had one and it failed, got given a replacement but i just dont trust it
it always went straight into self test mode so you couldnt use it for continuity
yes the t90 it only has led's.Is the T90 the one with LEDs? I have that in the bottom of my bag but now use the T5. The continuity is not the best and sometimes get readings of 8 ohms when the leads are 'zeroed'. I got the croc clips for it and the zeroed leads were back to normal ish so put it down to worn contacts on the probes. Generally use it for checking voltage, isolation and checking fuses are OK. But I wouldn't rely on it for any kind of accurate resistance measurement. Had it about four years and still works well.
i was trying to use it to bell cables out but as soon as the ends got shorted it went straight to self test.
the t5's are good. i prefer my multimeter for accurate measurements though, i would rather use my dmm than mft for an accurate voltage reading
i was working away as well when it broke......My T90 was OK also then. Wouldn't have upgraded to the T5 if I had problems with it! Must have got a dud there mate.
Reply to Test kit recommendations please in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
