W
wade88
Morning lads,
Having a bit of a moment and struggling to get my head around a few things (that are undoubtedly very straight forward).
Im trying to work out what available power i have to play with in anticipation of some heavy machinery coming into the warehouses in the next few weeks. We have three warehouses, side by side, but our main units power supply is well and truly maxed, so im looking to take some power from the neighbouring unit to supply these machines.
And so...The incomming live is broken down into three 100A fuses, then tailed into the meter. From the meter all three lives are then run to a seperate 100A isolator, and then split to supply various other DB's. Now im either being a total lemon, but i cant work out why three 100A supplies, giving a potential of 300A to be used where necessary, all consolidated into a single 100A supply - does this not remove the capacity for a further 200A?
That 100A isoltaor then feeds a DB powering warehouses lighting which are high pressure sodiums i belivew, around 400w each, and there are 11 of those, so no biggy, and then and office ring and lighting. again, nothing heavy. it is also split down to feed another DB with a single 63amp Type D breaker for two three phase motors next door which run large u-trough mixers. Im struggling to work out what i have available and where i can take it from. I understand without seeing the set up this post will probably be as useful as a chocolate dil*o but any input gratefully recieved.
I am also probably backing up to the firing squad wall a bit here but i need to ask these questions.
thanks chaps
thanks chaps
