V
VacuumRepair
Hi, Can anyone help with the repair of a Bona Mini Edge sander?
Replacing the mains cable, the internal wiring was damaged and I think it has been rewired incorrectly - its not working.
Was it you who replace the lead?
Reactions: Specialist
My husband.
I was going to suggest you take the offending item to a repair outlet, but 1 of you has some electrical qualification which should be enough to check the item out.
If you are unsure, have you checked the fuse in the plug top, could be worth your while checking before you go to the repairers.
  • Agree
Reactions: 1 person
Pete999, we both have qualifications and, yes, he should have been more careful but we are where we are. I was hoping for something more specific to avoid a hefty repair bill. Fuse checked, switch checked. I am well aware how stupid it looks as we have thinks brought to us that customers have tried (and failed ) to repair themselves - and we have a good chuckle.
No worries sheet happens
Found some stuff off their website but not all the links are marked with the cable colours. Its an expensive machine so wanted to talk through the possibilities before making any more mistakes.
Well if neither of you are sure, and it's an expensive bit of kit then take it to a reliable repair outlet. you know it makes sense, good luck.
  • Agree
Reactions: 1 person
assuming it's a d.c. motor, with a commutator and brushgear, generally both the armature and field coils are in series.
  • Agree
Reactions: 1 person
Hello tech talk has arrived
230v AC.
Two wires going to the thermostat and two to the motor coil, from the pcb, which is difficult to get at.
I would have expected a brown and blue to each BUT its now wired two brown to the thermostat - which his Highness "thinks" is how it was.
230v AC.
Oh so it's Hubby who thinks he knows it all is it?
  • Funny
Reactions: 1 person
just try different combinations:
1. it works.
2. it don't work.
3. it goes bang.
4 give it to a Scouser. it will be weighed in before you finish your tea.
1. it works.
2. it don't work.
3. it goes bang.
Not really a conclusive answer Tel is it?
who said i wanted to be conclusive. it's past beer o'clock, sun's shining, why be serious?
  • Agree
Reactions: 1 person
Pete999, He jumped in like the proverbial bull in a china shop.
telectrix, I don't understand No.4
Why was the mains cable replaced.
Reactions: telectrix
bloody, ell. my nephews have grown up quick. last time i saw them, they struggled to lift a fieata onto bricks.
  • Funny
Reactions: 1 person
sound, wack, sound.
So OP why did you replace the cable. That is a seriously expensive bit of kit but good quality I done the oak floor in my hall with their varnish products looks brilliant absolutely no discoloration to the wood.
It was broken, not just for the fun of it :)
I gathered that, so it worked fine until the cable broke, are you 100% sure the cable was broken.
Reactions: PEG
That's a good point, but yes, mains cable was replaced, it started up, broke the cables inside (not reassembled correctly), hence the need to rewire the insides.
Probably not a lot we can advise from a distance but if you can find an independent tool sales shop who also undertake repairs they should resolve the problem one way or another.
Hi,if it has succumbed to an internal wiring mishap,and the obvious fusing is in order,it may have fried that PCB or burnt out another component.
Might be time to ring the hire shop,and tell them your neighbours dog,played tug-of-war,with the cable. (In my experience,the more comedic and outlandish,the excuse,the cheaper the bill;))
Reactions: VacuumRepair
Wiring repair of floor edge sander
Electrical Tools and Products
VacuumRepair,
Pete999,
