Discuss Wiring repair of floor edge sander in the Electrical Tools and Products area at ElectriciansForums.net
So OP why did you replace the cable. That is a seriously expensive bit of kit but good quality I done the oak floor in my hall with their varnish products looks brilliant absolutely no discoloration to the wood.
That's a good point, but yes, mains cable was replaced, it started up, broke the cables inside (not reassembled correctly), hence the need to rewire the insides.
Probably not a lot we can advise from a distance but if you can find an independent tool sales shop who also undertake repairs they should resolve the problem one way or another.
Hi,if it has succumbed to an internal wiring mishap,and the obvious fusing is in order,it may have fried that PCB or burnt out another component.
Might be time to ring the hire shop,and tell them your neighbours dog,played tug-of-war,with the cable. (In my experience,the more comedic and outlandish,the excuse,the cheaper the bill;))
Reply to Wiring repair of floor edge sander in the Electrical Tools and Products area at ElectriciansForums.net
My friend has got one of those robot lawnmowers that automatically goes out once a day and runs around the grass. There is a single core guide...
Hi, The wire of my dehumdifier is broken (Meaco 20L Low Energy). The wire was being pulled over a period of time, which seems to have lead to a...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
My ASUS laptop has been sort of broken for a while, instead of replacing it we thought that it might be repairable? Its missing both hinges and...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
