Currently reading:
Alterations on old rewireable consumer unit
Discuss Alterations on old rewireable consumer unit in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
A friend has asked me to install a couple of extra sockets in there kitchen.
The consumer unit is an old Wylex with rewireable fuses so there is no RCD protection.
Would you carry out the work and recommend a new consumer unit/upfront RCD or would you not do the work unless they agree to have the extra work carried out aswell?
Some people are too tight or unable to afford the extra work so can't make them do it.
Cheers
ideally, to do an inexpensive compliant job. feed from the CU 30A 3036 ( and N) with 6mmtails into a stand alone RCD, then divert the RFC ( including your new sockets) from the CU to the outgoing RCD terminals
haha. debatable point. tails might then need upfront RCD thus making a whole bollox of it. ashas been debated before, a silly reg.badly thought out by suits who have less idea of the real world than they have of interstellar flight.
The regs say you can't make it WORSE (got them open in front of me), and that any alterations the existing stuff has to be right to start with (as in earth loop impedance, fault current etc). So you actually don't have to install a new consumer unit, but a new ring or radial has to be to standard (RCD etc). So provided you are simply extending what is already there, and not actually installing a new circuit, you are OK to just leave the consumer unit "as is". That said, wording can be tricky and although you would be within the law, it's not the best option as we all know.
As other folk have said, popping an RCD in there might be best, or even an RCBO. My consumer unit at home has one RCD before everything else, it's a pain but at least it's not going to kill anyone (hopefully!). But we also all know what will happen if you put an RCD in there straight off the meter tails, the whole lot will keep tripping and you'll get blamed for "doing something" because "it was ok before you touched it!".
Were I in your shoes, I would offer to put the sockets in, make it clear that although legal is not best, strongly advise an RCD be fitted at the very LEAST, and urge a consumer unit change sooner rather than later and perhaps provide some sort of documentation outlining this. Just my 2 pence, but then I'm only starting out as a spark the regs are very fresh in my mind as I've just had two weeks of exams and reading (though I do have 14 years offshore and military engineering behind me so do know a little about electrical lol!)
I would go with Tels suggestion, not my option, but if you friend does not want to spent on CU upgrade, not much else you can do really, try and persuade him that all round it would make sense to upgrade the CU. Just MO.
LOL. Which Regulation states that?
It doesn't say that verbatum. I now don't have the regs in front of me, but something along the lines of serviceable pre-existing installations do not need to be brought up to modern standards (such as red & black cable, old fuse boards etc), new circuits have to be up to spec but additions to existing circuits need only ensure earth impedance, fault and short circuit current etc are within limits, bonding arrangements are correct etc. So in this case, adding to an existing ring needs no consumer unit change, nor (technically) the addition of an RCD. Thats not to say an RCD should not be fitted (you need one really), my point here is that to satisfy regs you need only install one if there's a new circuit going in, not if you are adding to an existing one.
Or, to summarise, you can't leave an existing installation in a worse state (by this I mean for complying to the regs) but you do not have to rip out and replace old stuff just because it does not comply with current regs.
A point to note here is also that the current 17th edition regs are not statutory anyway, they are a guideline. Hope that clears up what I meant..?
what you have just said about existing installation not having to be brought up to current regs. is true, but any work that you do has to be to current regs. i.e even if existing sockets have not got RCD protection, then any that you fit must comply with current edition of BS7671. i.e. RCD protected id required by current regs.
The 'regs' have never been Statutory (capital S) and your statement above puts at variance your earlier post when using words like 'legal'.
To be honest it's hard to give the OP a definitive answer unless the installation method is known.
Yeah, work done has to be within regs, but this very scenario came up while I did my 17th edition, I'm almost certain that the instructor said the correct thing to do (within the law, not the *best* thing to do) is to do your work (the sockets) to regs, but altering the existing wiring to modern regs is not required. Though in fairness we were discussing putting sockets at daft heights rather than RCDs on an existing commercial radial (a job I have booked in for later) but I'm sure as I said the consensus was addition of RCD was not required but *should* be done, but in the event it was not installed, it should be clearly documented as such. However, it's a moot point, in really-real world an RCD should be there, and I bow to your experience, I could well be wrong. I am just a noob!
Point taken, though capital S or not is just being a pedant. I am using my phone with autocapitalisation and I just didn't bother hitting "shift" while typing. Lets not get bogged down in pettiness, I used the word "legal" rather than "best fit complient with regulations but not necessarily in line with best practice" - it was less of a mouthful. But thank you for your correction nonetheless, I shall try and be more concise and keep an eye on my capital letters in future. *mwah* ---
A departure from bs7671 is something that doesn't strictly comply but offers at least the same level of safety as compliance. If the socket was installed for a specific piece of equipment then it would have to be labelled as such to omit RCD protection but also the installation method would have an impact on this.. For example T&E burried in a wall at a depth of less than 50mm. Again you could omit RCD protection in an installation other than in a dwelling for the new sockets your installing if you produce a documented risk assessment and couple it with the installation/minor works certificate but you being the designer, inspector and tester would have to have a very good reason for the lack of RCD protection especially if something happened and you found yourself in front of a judge. As above the installation method would also have a bearing on this as other regs have to be considered. Since the introduction of Amendment 3 the old get out of jail free card for the omission of RCD protection if it was under the supervision of a skilled or instructed person is no longer an option as the definition of skilled and instructed was being abused.
Reply to Alterations on old rewireable consumer unit in the UK Electrical Forum area at ElectriciansForums.net
