First Day of AM2 exam finished! Just need alittle bit of help. | on ElectriciansForums
Discuss First Day of AM2 exam finished! Just need alittle bit of help. in the UK Electrical Forum area at ElectriciansForums.net
RyanF
Newcastle Upon Tyne
first day done of my AM2 exam. Just wanted to let people know what I done and if I will loose any marks.
So first of all risk assessment and safe isolation. I completed the risk assessment no problem at all and the safe isolation I completed fine as well asked for permission to isolate, prove, test, prove, lock off and warning notices, key in pocket etc.
Install section:-
Lighting cicuit took 1.5mm twin and earth L and Neutral and cpc to my first switch, fed the common with my L and Neutral in the back switch. I then took a 3 core 1.5 to the second swith which was grey as my neutral which went into the back of the wago, brown as my S/L with brown tape and the other brown as my other S/L. To the intermideate I then took the 3 core and looped the Grey in the back as a Neutral again, then took my brown and black to the top or the intermediate. Again, sleeved correctly. Another 3 core out to my last switch done the same again brown/ black S/L and neutral into another wago. Then, 1.5 up to the light as my neutral in the wago and the brown into th common. All cpc linked in wago is back of switch as well. MCB 6 Amp Type B
Ring Main
2.5mm and 1.5mm cpc from db to first socket, though to the spur, and to the last socket, last socket then back to the db. Then took 2.5 and 1.5 to the outdoor socket on the load side of the Switched spur. Ring on a 32 amp RCBO type B.
Bonding
10mm for water and seperate for gas.
Gas to first part of the pipe before the T joint.
Water connection just after the stopcock/ first section of pipe. Back to the db seperate and labeled.
Fb 200
Supply from DB to non switched spur. From
Non switched spur up to co2 alarm. A seperate length of FB 200 On cable tray using P clips and bolted to the tray. tighting of glands etc also on a Mcb 6 amp type B.
3 phase and neutral isolator. 4 core 2.5mm from db to isolator, again banjo and glanded at both ends. Used 1.5mm cpc as bonding cable inside db for the banjo. Then 2.5mm 3 phase colours and 1.5mm cpc to commando socket. Then looped neutral in back of isolator using a wago. 3 phase and earth connections.
3 phase dol starter
3 phase, neutral and cpc to dol starter.
Sy 3 core and earth to motor box. Glanded off and cable tied to cable tray. Marked 1 as L1 , 2 as the Black phase and 3 as the Grey phase.
S heating plan ill do tommorow along with thermal overload to work out of the motor and the data points. I still have 3 hours left.
Does all sound good? Or any hints or tips on things ive missed out?
Inspection and testing tommorow and fault finding
Cheers!
Install section:-
Ring Main
Bonding
Fb 200
3 phase dol starter
Cheers!
Don't call it a Ring main, (Ring Final Circuit)
Erm I might be reading it wrong but you’ve took a live and neutral feed to 1st switch but then taken a 3 core and earth to 2nd switch and for an intermediate switch for 2 and 3 way control.
If so then why have you made the grey from the 3 core a neutral?
If it’s 2 way then black as common marked with brown over sleeving and the grey wants oversleeving brown also as it’s a strapper.
The only neutral you should have in the switch is the mains fed one from the DB then out to your light.
If I’ve miss read your txt then ignore me.
Erm I might be reading it wrong but you’ve took a live and neutrals feed to 1st switch but then taken a 3 core and earth to 2nd switch and an intermediate switch for 2 and 3 way control.
I may be wrong, but I think the OP has taken a L and N to the first switch on a 2 way switching circuit and has carried the N conductor through to the second switch and at the 2nd he will have a 3core, 2 strappers and a N at that switch where he will then run a 2 core and earth from the light, this cable will be a N and SL, again if I have read the post wrong then ignore this post.
Do you not take a mains from the DB to the first light switch then your s/live and neutral to the light wired from the first switch (which is a 2 way)containing your permanent live and neutral?
Any 2 way and intermediate switches then it’s just 3 core from your first switch to your intermediate then a 3 core from your intermediate switch to last 2 way switch.
Why carry a neutral all the way through?
On the AM2 they require a neutral at each switching point on the lighting circuit.
So T&E from MCB to 1st switch. 3C&E to intermediate and 3rd switch, then T&E to luminaire.
Technically you can use an colour core for strappers, neutral etc as long as their identified/sleeved.
Because he has to take SL and N from the last switch in the line
So there’s a neutral at the intermediate switch? Which is pointless.
Am I reading that right?
Different from when I did it.
It was about 17 years ago mind
Oh well I wired it as this drawing is drawn. You have to loop a neutral in the back of the switches. So I took a L and N to the first switch to feed the common and Neutral in the back of the switch.
Then a 3 core taking two S/L to the intermediate from the first switch. Looped Neutral in the back again. Then a length of 3 core to the other 2 way switch which has a 2 S/L’s and a neutral. Again looped in the back. Picked uo the neutral in the back and up to the light on a seperate 1.5 which then brown to the common up to the light ?
Is this wrong? Or right?
I just followed this drawing.
Heres the drawing
[ElectriciansForums.net] First Day of AM2 exam finished! Just need alittle bit of help.
So what ive done is correct then in my exam? Im panicing like hell now!?!?
Do it as per drawing Ryan it’s what you have to do and it shows you can read drawings also.
There will be a N at all 3 switches in a wago I should imagine or some other connector.
It’s to allow for smart switching. But TBH I would think it’s to check you actually follow the wiring diagram rather than just wade straight in.
Personally I think they should do one circuit this way and one using the three plate method.
We got told to loop the neutral in the back because some of the new switches have looped Neutral Terminals in the back of them now. Its also at a later date some new smart heating technology stuff needs a neutral at the switch. Hense why its been advised to do it this way.
That’ll work. Have fun wiring up the heating...
Im doing that tommorow along with the data point and tidying up cables/ checking conductors are correctly wired etc.
Ive got just under 3 hours left for the Install then onto inspection and testing.
Would I loose marks if using the wrong crimps on the cpc on the banjo to MET on the armoured? Etc.
If the wrongs crimps are provided then ask for the correct ones. If they say use what there is then just crack on.
Problem is the test centres are on a tight budget so they have to use what they can lay their hands on.
Well ring final cicuit then....
Not trying to be a smart arse Ryan, but get the simple things right and the rest should follow a Ring Main is a distribution ring as in LV or HV distribution, I know ot was always referred to as a Ring Main but not anymore, Ring Final Circuit, as opposed to a Radial Final circuit. and good luck for tomorrow.
Reply to First Day of AM2 exam finished! Just need alittle bit of help. in the UK Electrical Forum area at ElectriciansForums.net
That's how I did it but I can't see why either wouldn't be acceptable.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
5K
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
Re highlighting for a possible response
