- Reaction score
- 9,055
I agree with some of that.
the light is an indicator of power used, so many pulses per so many kw/h
I do agree that there would be a very low voltage across L to N if the N was disconnected before the meter.
but you can get some strange things happening with supply faults.
currents can pass from live to earth
currents can pass from N to earth
enough of a difference in voltage can be generated to light up an led.
A spark with some simple test equipment would take 5 minutes to work out where the problem lies but it would be unwise to advise where it is without seeing and testing.
DEFINATLEY A FAULT FOR A PROFESSIONAL TO CHECK☑
