Fixing wiring above suspended ceiling | on ElectriciansForums
Discuss Fixing wiring above suspended ceiling in the UK Electrical Forum area at ElectriciansForums.net
Stirling
Hi all
regarding securing cables above suspended ceiling. Is there anything against the regs from tie wrapping down a threaded rod to a light fitting. To keep it off the ceiling. This is run in FP200 so has earthed shield inside ?
Thanks for the replies, no support systems in the ceiling only have HVAC support systems, so was planning on running just using this system as it’s close to where the light will be getting installed and tie wrapping down the threaded rod with metal ties. Just didn’t know if this would be a good idea or not ?
It can be as simple as fixing metal strap banding to the upper ceiling.
this , some all round band simply screwed and plugged to the concrete ceiling...
far better than plastic cable ties to the ceiling grid support rods
I'm just enjoying somebody intending to install cable properly above a ceiling rather than just slinging it across the tiles like most other Tuesday's.
I did some work at a big leisure centre just before lockdown and pretty much every single alteration to the original wiring was slung in above the ceiling grid.
there was literally miles of flex & twin and earth chucked in resting on top of the grid. It was quite something and I’m just amazed the ceiling hadn’t collapsed under the sheer weight of cables ...
Fitting a designed tray system before the ceiling will often save time and money as well guaranteeing compliance.
Retrofitting tray for a single/few cables above a suspended ceiling is a right pain and will be cost prohibitive.
A few loops of strap banding off the original ceiling takes the weight off the susspended ceiling and provides against undue collapse in a fire, if your that way inclined.
Not pretty but does the job.
I've done the above to relieve some weight off a saggy ceiling, managed to get some degree of separation with data/fire/power as well.
Reply to Fixing wiring above suspended ceiling in the UK Electrical Forum area at ElectriciansForums.net
It isn't just about premature collapse that is more dealing with the method of support. Ignoring this, cables should be correctly supported to...
Brilliant thank you so much for your help 😊 x
No, that should definitely not be left like that. It needs replacing with a suitable maintenance free junction box. Are all these circuits RCD...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
