Feb 27, 2022
Derbyshire
Other
If other, please explain
Qualified and practising electrician, also member of the Energy Institute, and Chartered Environmentalist. Specialise in renewable energy systems and have written CPD articles for the Energy Institute on IoT and grid connected energy storage, e.g. https://energyinst.org/__data/assets/pdf_file/0004/538879/Series-14-Module-9-March-2017.pdf
Business Name
T4 Sustainability Limited
I find this one reliable.
Thank you ! That's spectacularly cheap too. Does it read zero at zero ?
(The only reason I ask is that some cheap clamp meters I've bought over the years don't, and it can be quite irritating.)
Cheers, J/.
Reactions: nicebutdim
Cheers, J/.
My experience is that it does.
It's the same meter that @pc1966 regularly links.
When I've compared it against the TEK775 and Megger DCM305E, readings have been the same or very close on every occasion.
Ah yes I remember now. Thanks.
Having both I can agree with that, it surprised me if I'm honest. Saying that most are rebadges of other models so it was nice to see thr Megger was different.
I'll admit I was a big thick when I got the Megger as I thought "oh this must be how tht IClamp/VClamp features work on the 1700 series....no, no they aren't, tht actual IClamp and VClamp are much more stupidly priced 🤣
I'd like to have the Megger, but needed one for a specific task at the time and it seemed to be worth a punt. Turned out to be well worth taking a chance on. I'd like a meter that also measures DC leakage, but haven't yet been able to justify the additional cost.
That is a really great price! The AmeCal one on ebay which I already thought was a bargain is a rebrand of that and is more money.
Got a TEK775 free with an MFT (also uses the same style of housing) but sold it as performance was identical and it was the more expensive of the two.
Can I ask how much "additional cost" comes to in euro, s and what particular brand caught your eye.? I also want to get one with the capacity for measuring DC leakage
I can't remember the exact cost, but do recall being taken aback by the vast difference in price between an AC earth leakage clamp meter and one that also measured DC leakage.
I do, however, remember someone recently mentioning a more reasonably priced meter with DC capability.
Reactions: LastManOnline
Why does the technical doc for that farnell item state 60Hz?
Thanks, @nicebutdim
I don't know either!
But I have to think it might matter...but my technical knowledge is not great!
Thanks, @nicebutdim
It may and it may not. I note the Megger DCM305E data sheet mentions both 50 & 60Hz.
Perhaps there is relevance or perhaps the datasheet was initially written with another market in mind. I was simply happy with the figures this displayed and their veracity when compared with two other meters.
Small variations in frequency, say 50Hz versus 60Hz should not make much difference to the accuracy. Very low and the magnetic circuit is unlikely to couple as much current in to the measurement coil, very high and probably the meter's noise filtering is going to also cause it to under-read.
That CPC meter also looks identical to this much more costly branded one:
My money is simply at it being on thr global market and 50/60Hz being the most common global frequencies, as such advertising it works on both frequencies means it targets a larger audience and not much more fancier reason than that.
Derbyshire
Other
Business Name
Earth leakage clamp meter
Electrical Tools and Products
John Beardmore,
Sadsyndrome,
