Jul 8, 2019
329
105
1,218
Mid Wales
Retired Electrician
I recognise those frequencies, it is not a Walkie Talkie, it's a ham radio, and one needs a licence to use it. PMR466 is what I would call a Walkie Talkie.
The forum has no influence on what shows up on advertising.
All that happens is that the forum reserves a bit of space on the page for adverts, then google, or ad choices or whoever insert whatever advert they like.
The content of ads should follow your own searches via cookies on your computer….. or from your IP address of your house… meaning you may get adverts for all your families searches as well.
Not just typed searches either. That smart speaker in the corner constantly listens to you.
It's advertised as a walkie-talkie, just because it's a multi band transceiver capable of covering some ham bands doesn't mean it's not one.
You don't need a licence to use it to listen.
Reactions: davesparks
You do in the UK.
The more interesting question is what licence is needed - does "I'm not going to press the Tx button" make it count as a receiver rather than a transmitter ?
Reactions: James
Sorry, that's no more authoritative than "some bloke down t'pub said so".
The Wireless Telegraphy Act was (last time I looked into anything) fairly clear that (roughly) it was illegal to listen to anything you weren't licensed to listen to. I'm sure the licensed amateur bands would fall under this.
The Radio and Telegraphy Act, also known as the Wireless Telegraphy Act, is the primary legislation governing the use of radio spectrum and radio equipment in the UK. It's managed by Ofcom,
From Ofcom
Generally, the use of radio receivers is exempt from requiring a licence.
Typically, receivers and scanners can only be used for ‘general reception’ such as licensed broadcasting stations and hobby radio
You don't actually need a radio.
HamSphere:
This is a virtual amateur radio transceiver that allows you to connect with ham radio operators and enthusiasts worldwide, even without a license.
You don't need a licence to listen to Radio either, including bbc radio which the likes of some walkie-talkies have the capability of covering.
It doesn't say you can't listen
(a)he uses wireless telegraphy apparatus with intent to obtain information as to the contents, sender or addressee of a message (whether sent by means of wireless telegraphy or not) of which neither he nor a person on whose behalf he is acting is an intended recipient, or
(b)he discloses information as to the contents, sender or addressee of such a message.
(2)A person commits an offence under this section consisting in the disclosure of information only if the information disclosed by him is information that would not have come to his knowledge but for the use of wireless telegraphy apparatus by him or by another person.
Mid Wales
Retired Electrician
Misleading adverts on this forum.
EricMark,
mainline,
