S
screechyboy79
Has me in a state of confusion...
We live in an early 80's house so the wires coming from the ceiling are 3 red, 3 black (one with blue tape, assuming they ran out of red) and 1 earth. Our new ceiling light has 3 blue, 3 brown and 1 earth.
I have tried a multitude of combinations and have failed to get the light to work at the same time as the switch i.e if the light does come on the switch does nothing. Other attempts have stopped other lights downstairs working correctly.
Could you possible advise how you would deal with this situation? I feel like i have tried nearly every combination.
Thanks in advance
Take the feed to the switch, it's much easier? Anyone else want to discuss the pro's and con's of this method on New Year's Eve?
Funny you should say that.
Today I've been looking at the landing light at my own house with the view of converting it to 3 way switching and adding an extra light and I have the choice of feeding the switch or using the more "conventional?" method.
So far - and after half a bottle of Port which because of the meds. I'm taking I shouldn't have - the feed to the switch looks like a nice option.
If all the other fittings work then
Could be any of the following 4 (and possibly some others):
a dead on arrival fitting
OR
bad lamps out of the box
OR
Dead light switch
OR
Switch cable damaged by screw for new light mounting bracket.
YOU may read by lamplight you posh bugger ... I have to make do with a candle.[/QUOTis that when sitting on the bog, reading last week's daily mirror, warming your arse coz. you plumbed the bog into the hot water instead of the cold?
The simple job of a new ceiling light
screechyboy79,
tidyboiler,
