Discuss don't use rcbos for TT in the UK Electrical Forum area at ElectriciansForums.net
I’ve only got two RCBO’s in my flat, they’re coming out as soon as I get around to it.
I priced up Hager DP units, good job I was sat down when I saw the price. There’s bags of room in the board so a couple of MCB’s and a second RCD will be going in. It also means I can split the two rings between the two RCD’s. BTW it’s a 16[SUP]th[/SUP] board.
Before you ask, it’s how I found it when I moved in.
Oh dear Tony! Carrying out electrical work in a house without being NICEIC registered! Don't be suprised when the Part P police come a'knocking! A cowboy now as well as a Yorkshireman, it just keeps on getting better and better!
but i am...and he rang me up asking if i`d do it for him....Oh dear Tony! Carrying out electrical work in a house without being NICEIC registered! Don't be suprised when the Part P police come a'knocking! A cowboy now as well as a Yorkshireman, it just keeps on getting better and better!
which kind of blows geordie`s sly comment at #21 out of the water as well......:27:
oh so he told you did he?...More like Tony phoned your mother and she told you get round there and do it.
only half the story as i was also told that if i didn`t i was to `get up them stairs without no tea`...
yeah...she has.I like your mother ... she has style.
my style comes across loud n clear in my posts & replies...didn't do a good job of passing it on though. :24::tank:
not much then against my..erm...5 i think ...at the last count...can't match that. i only got a couple of zippos.
well no...but i bet you not got a harley davidson one. that's worth 3 "ordinary" ones.
I do & so do you, you'll have to visit the other forum to see & purchase them though.....................Do you know of any manufacturers that make single module double pole RCBO's?
What they are trying to say is RCBOs are single pole and should not be used where double pole is required, They are not saying do not use on tt, why would they?
I think they are......In a TT installation neutral is also classed as a line conductor,And as such if isolation to a particular circuit is required for maintenance or alteration we are supposed to be able to isolate both poles without having to knock the whole installation off via the mainswitch RCD. I am thinking that double pole CBs could be the answer(rather than dp rcbo's) I know that they are available,and you are still 30ma protected via main switch rcd. I'm a wee bit surprised mr Niceic hasn't made an issue about this before.
Reply to don't use rcbos for TT in the UK Electrical Forum area at ElectriciansForums.net
