I'm more than competent on 3 phase and single phase , it's a 3 phase DB using all ways as single phase circuits , so the theory for 3 phase without neutral is N/A
i was myself thinking there is either borrowed neutrals everywhere or something else in the set up giving the required neutrals
Forgive me Tel, what I should have said was I don't believe that there's any being anywhere that is superior to me.trev. you can't possibly be a geordie and an atheist, as all geordies believe that they are god. ergo, you believe in god, so atheist, you ain't. truth be told, you need to have been born in liverpool to have aspersions as a deity.![]()
that's more like it. with that, you could possibly become an honorary scouser ( 5 week course and £6000 by bank transfer should fix it)Forgive me Tel, what I should have said was I don't believe that there's any being anywhere that is superior to me.
It is amazing what you see on Facebook Trev lolBloody hell Mike, what kind of question are you putting into a search to come up with results like that?
What kind of person are you?
This is absolutely ridiculous!!!
Op you clearly have no right to be carrying out Eicr's, it is painfully clear you are out of your depth, to ask such a basic question scares the
crap out of me.
For god sake put your tools away and go and get a job that requires less Brain cells.
Enough is enough, when will things like this stop.
If there are borrowed neutrals all over the place then the testing which you should have carried out given your suspicions would have confirmed this or proved your thought process wrong.I'm more than competent on 3 phase and single phase , it's a 3 phase DB using all ways as single phase circuits , so the theory for 3 phase without neutral is N/A
There are no 3 phase end circuits involved there is 32 single phase circuits that's the questionFor f***s sake, why would you need a neutral on a 3Ph circuit!
Go away before I loose my temper.
Apologies Old jag![]()
Well that confirms my opinion mate, FB is crap and should be avoided at all costs. I was hounded into setting an account up and I have to say it's the biggest load of self centred, attention seeking, whiney garbage that I've ever had the misfortune of seeing.It is amazing what you see on Facebook Trev lol
JesusApologies Megger that your introduction to the forum is not a good one but you really have to understand that if your asking this question at your level then something is seriously wrong.... are the so called single phase ways not in fact separate fuse holders for a 3 ph load and not 3 single phase circuits... again not realising this is poor reflection on your competence.
Sod off, you just want to lower me to your levelthat's more like it. with that, you could possibly become an honorary scouser ( 5 week course and £6000 by bank transfer should fix it)
