Discuss 4.8kw electrical combi oven/steamer 3 phase in the Electrical Engineering Chat area at ElectriciansForums.net
In a small restaurant theres a single phase supply just wondering what size converter i would need to convert 3 phase to single phase and what size mcb to install into the ccu
What size single phase supply is there into the restaurant and what's the total load of all the other equipment?
How many pins thas that Blue plug got that's on the oven?
That's a single phase plug. Do you have a picture of the oven rating plate?
1st thought is that the appliance is either 1 phase or 3 phase, dependent on how it's wired.
Hi There should be a data plate on the left hand side if you post a picture of that i can check its requirements for you as I am a Commercial Catering Equipment engineer authorised by the manufacturer of these units
Reply to 4.8kw electrical combi oven/steamer 3 phase in the Electrical Engineering Chat area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
