Search the forum,
Discuss BIg difference between Inverter and Meter readings in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Went to look at a 10KW install today that was installed last june and company went bust.
The Power one 3 phase inverter reads 4274Kwh's where the elster A1140 reads only 4066Kwh's
I havent seen one with this much difference before is this an acceptable difference?
Ok, then it probably isn't a volt drop issue then! I can't comment on the accuracy of the P1 but the meter is certified for accuracy to a small fraction of its base current, so I would doubt the meter is at fault tbh
Reply to BIg difference between Inverter and Meter readings in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
