Currently reading:
Brightest GU10 LED - or maybe something else ?
Discuss Brightest GU10 LED - or maybe something else ? in the UK Electrical Forum area at ElectriciansForums.net
Viktor
Hi All,
I'm not an electrician but trying to research the following issue for our lighting needs :
I am replacing GU10 halogen lights with LED spotlight but have found the following problem :
I don't want to save electricity I want a much brighter living room/kitchen.
In theory since all the sockets rated 40watts I think I could get a 40 watt LED bulb that would be multiples brighter but so far the best I've found is only 9 watts and 850 lumens.
So the questions is if there's any brighter GU10 bulb out there? In theory a 27 watts LED could be around 2550 Lumen but I can't find anything online.
Floorstanding lights have this amazing 4000 lumen bulb, 3 of those would be great for our space but they look terrible/don't fit the style of the rooms and of course I couldn't put any of those in the middle of the kitchen.
Any comments, suggestions or ideas are welcome.
Thanks,
Viktor
Just to second getting some wider beam LEDs. I've got 4x 110 degree 400lm GU10s that illuminate my living room, which is about 5m x 4m. Brighter lights aren't worth anything if they're only pointing at a 1m spot on the floor
I think the problem with cutting larger holes is the Landlord may charge megabucks to re-instate the original lighting (bang goes your deposit). At least with surface mounted LED panels as @HandySparks has observed they are easy to remove/re-instate. You could leave the spots as is and just have the panels switch on.
Reply to Brightest GU10 LED - or maybe something else ? in the UK Electrical Forum area at ElectriciansForums.net
