Hi all, I'm new here but wondering if anyone could tell me if I have a dangerous situation or not?
I have a double power socket attached to the wall that I've turned off...however it's still powering my phone charger...So whether it's on or off at the wall it makes no difference.
Only one side of this double socket is affected. Just wondering if this is this dangerous? Or can I leave it a few days to fix (as I'm away this weekend).
Thanks,
JImmy
Sounds like the switch has packed up. Just to be safe don't leave anything plugged into either side and get a local spark to swap the faceplate.
As long as the wiring is OK it's an easy enough job that won't take long or cost too much.
sounds like it's just the switch has failed. does it feel different to others when you flick it on/off? if you leave it with nothing plugged in, it should be OK
Kent
Dangerous? Plug switched off at wall but still powering things!
Jimmy Ward,
mickfred,
