SibertSolar
Hi all,
I've had a couple of enquiries lately from clients who have been (somewhat surprisingly) informed by their DNO that the generation meter is not Ofgem approved. Why, all of a sudden, are DNO's deciding that MID approval is not adequate/accepted? Don't they understand the history/nature of MID/Ofgem approval?
Anyone else experiencing this annoying trend?
The only experience I have had is contributing to the other thread on it.
1. The DNO is 100% wrong if they are trying to limit the range of generation meters being used to OFGEM approved.
2. I cannot see why they are interested anyway as they are not involved in the contract that is about the gererated energy reading. Indeed it is not clear on the G83 appendix 3 form whether they are asking for the generation meter type and serial number or the existing import meter type and serial number. All it says is "Electricity meter(s) make and model:"
Regards
Bruce
Thanks Bruce, yes, I saw your other comment in the PRO1D thread (?), I can't see any reason why this has suddenly become a supposed issue....
Are these pre December 12Th installs ?
Could they be looking at eventually making the fit applicant install one of their "approved" meters but then restarting their fits contract from that point ?
I know it smacks of conspiracy theory , but !
We nearly fell foul of something similar on a couple of +50kW jobs last July with inport /export meters that could not get fitted in time .
This is pretty much as I understand it:
"The MID (Measuring Instruments Directive) is a new European Union (EU) directive aimed at creating a single market for measuring instruments across the EU. MID took effect on October 30, 2006. The scope of this Directive is to guarantee to the users a high level of safety and reliability of the measuring instruments, protected against data corruption, ensuring in the meantime the free circulation of certified measuring instruments within the EU. Annexes define how the instruments can be declared as compliant to MID. Notified bodies are authorised to carry out testing, and the certification issued by one of the bodies shall be accepted within the EU within any limitations. This MID is a replacement for the old OFGEM approval in the UK"
I suspect it is a misundertsanding by someone within a DNO who has not kept up to date. Coincidentally, I had a few messages today about planners who until today had not realised the conservation area permitted development rules had changed in 2008. If they can be behind the times I am sure the DNOs can similarly be.
Reactions: 1 person
Are the DNO concerned over MID B meters - which are generally not supposed to be used for 'billing purposes'? OFGEM give no guidance on this as far as I can find.
But I also fail to see what business it is of theirs to get involved with meter equipment that is owned by a householder.
I'll check with a couple of contacts and see what I can find out.
NPower aren't a DNO are they? I agree that the generation meter is none of the DNO's business but in this case wouldn't NPower simply be the energy supplier/FIT provider?
The guidance from OFGEM to electricity suppliers simply states:
All meters used in the FIT scheme must comply with the relevant metering legislation. These include:
Schedule 7 to the Electricity Act 1989
The Meters (Approval of Pattern or Construction and Manner of Installation) Regulations 1998, SI/1565
The Meters (Certification) Regulations 1998, SI/1566
The Electricity (Approval of Pattern or Construction and Installation and Certification) (Amendment) Regulations 2002, SI/3129
The Measuring Instruments (EC Requirements) (Electrical Energy Meters) Regulations 1995, SI/2607
The Measuring Instruments (EC Requirements) (Electrical Energy Meters) (Amendment) Regulations 2002, SI/3082
The Measuring Instruments (Active Electrical Energy Meters) Regulations 2006, SI/1679
The very last one listed there, with ref SI/1679, is the UK legislation that implements the EU Directive on MID meters.
Many thanks Ted, much appreciated.
Yes, I think NPower are the FiT provider actually, apologies for any confusion.
what they mean is that it's not on the list they're using internally to confirm the meters are certified. Problem with MID stuff is there is not central list for it, so each electricity company needs to add each meter manually to their lists if they've not come across them before.
We had similar issues with the inepro pro75D meters a while back, but got it resolved by sending a photo of the meter showing the MID accreditation mark on it, and that meter was then added to the lists of 2 of the suppliers who'd been having problems with it.
Reactions: 1 person
Thanks Gavin, that could well be the root of it. Mind you, it's the Iskra MT171 which is a very well established model but you never know! I've just got my hands on an Ofgem approval cert for these meters from way back in 1992 so that should put this issue to rest hopefully.
Reactions: 1 person
probably just a balls up then. I get the impression that some of their meter lists aren't very easy to search / more than one list etc.
DNO's stating that gen meters are not "Ofgem Approved"
SibertSolar,
Gavin A,
