B
BruceB
I have been asked to quote for about 7 kW PV on a single storey commericial building in a town. The x4 roof areas all slope at about 10 degrees to the horizontal. It has many characteristics of a flat roof rather than a pitched roof (no apex). No time for planning permission so want to meet non-domestic PD rules. A pitched roof means I can come 200 mm from surface; a flat roof means I can come a metre above, which might be useful for an east/west array.
Has anyone seen any guidance on (or got any experience of) how sloping a roof has to be to no longer be considered flat under SI 2012/748?
0-10 degrees is classified as flat in HSE guidance, so I'd go with that in the absence of anything else.
Reactions: 1 person
Hi Bruce,
Any roof with a pitch less than 5 degrees is considered flat in the BSEN1991 and the BS6399 therefore the roof with a 10 degree pitch is a pitched roof.
If you need any structural reports (includes static, wind & snow loads) please do not hesitate to contact us.
Kind Regards,
Bryan McGrory
BMG Surveys Ltd
BMG Surveys Ltd. - Home
0141 532 2322
I was under the impression that commercial installations were not covered under permitted development rights?
They are permitted development and have been since March 2012, subject to 50kWp limit and other parameters.
On 25th March 2015, non-microgeneration (>50kW) then also got a load of dispensations and so also got permitted development, subject to a load of conditions.
Reactions: 1 person
Flat roof or pitched roof?
Thread Tags
Tags Tags
flat roof
BruceB,
Worcester,
