Currently reading:
Found cabling under floorboards, is it safe?
Discuss Found cabling under floorboards, is it safe? in the DIY Electrical Advice area at ElectriciansForums.net
Take a look at most Diy and even many electricians attempts at connecting downlights, that sort of mess is common
It does need someone to alter the means of connection and to fit a enclosure but more import is to check on the suggested borrowed neutral possibility
The connections have apparently been like that for a while with no sign of overheating,so instilling the fear that its going to burn down tomorrow may be bordering on the sometimes electricians hysteria :)
  • Agree
Reactions: 123
On the basis of this photo, I would recommend you get a local spark to investigate and fix properly ... Then look at other circuits....
Maybe an EICR to put your mind at risk
The picture puts my mind at risk in the first place....
Reply to Found cabling under floorboards, is it safe? in the DIY Electrical Advice area at ElectriciansForums.net
