telectrix ~ Mentor Arms Supporter Sep 5, 2010 71,498 72,015 18,688 78 cheshire/staffordshire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Electrical Engineer (Qualified) Business Name Telectrix Mar 16, 2015 #2 welcome to the forum. 3 months, you'll be as daft as the rest of us. :49:
Pete999 ~ Arms Supporter Mar 14, 2013 25,716 18,746 18,688 79 Northampton If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Retired Electrician Business Name None Mar 16, 2015 #3 Valkommen
Spoon ~ Mentor Arms Supporter Jun 30, 2010 9,196 8,031 10,256,798 Lancashire If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Electrical Engineer (Qualified) Mar 16, 2015 #4 Welcome
rapparee ~ Arms Feb 24, 2011 1,401 1,311 1,688 Ireland If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? Ireland What type of forum member are you? Other If other, please explain Industrial Electrician Mar 16, 2015 #5 Well hello
Pete999 ~ Arms Supporter Mar 14, 2013 25,716 18,746 18,688 79 Northampton If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Retired Electrician Business Name None Mar 16, 2015 #6 :welcome:
