Discuss mounting systems for welsh slate roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
we've used same hanger bolt system on several slate roofs it is an approved method and the washers are epdm rubber same as these rubber roof coverings which have long lifespansI really don't like the idea of rubber seals. Sounds to me like a recipe for leaks in the future.
As above post has mentioned it is not just a standard rubber.
Tell me this does not look good! One of my installs!
One other thing, have you found that over-tightening of the bolt cracks the tile?
How do you sell this to your clients? I bet you get some concerned customers about drilling a hole straight through their roof. We haven't worked on slate roofs (Yet) but I would be concerned if it were my roof.
How does this comply with building regulations also? You should not drill a hole more than 10% of the rafter width. I assume this bolt is a M8 or M10?
Not knocking your install and I can't think of a practical solution either, its just a question!
Some pictures of the finished article may be good as well.
Reply to mounting systems for welsh slate roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
