R
richeeerich
Can someone offer some advice please?
I would like to remove an old outside light fitting on a switch, currently wired as attached photo:
home - outside light
blue - blue
yellow/green - yellow/green
blue with brown sleeve - brown
three brown wires from home into their own terminal with no connections
black wire from light fitting into dark brown wire of light fitting.
The new light fitting only has four terminals, neutral (N), earth (E), live (L) live switch (LS).
So my query is that there is no loop (of black wire into brown) like the original light fitting so should I leave the three browns wires in their own terminal and just connect the blue with brown sleeve into the LS or would this cause a problem?
blue - blue
