Currently reading:
Pond pump still tripping rcd
Discuss Pond pump still tripping rcd in the Australia area at ElectriciansForums.net
P
peteelecs
Pond pump is still tripping RCD which means I loose all power to socket outlets upstairs downstairs and kitchen (with freezer in it).Why doesnt mcb trip instead and what could be causing RCD to trip.Any advice would really be appreciated.
or a possible poor connection on the fuse/fuse carrier, causing a bit of arcing. only time will tell if that has solved the problem.
Place your bets please.
2/1 it will trip again within the next 48 hours.
5/1 its the pump on its way out.
9/2 its an accumulated earth leakage
10/1 all of the above.
Place your bets now :).
Reply to Pond pump still tripping rcd in the Australia area at ElectriciansForums.net
