- Reaction score
- 0
Discuss Problems installing lights in the Lighting Forum area at ElectriciansForums.net
No, they are also connected inside.Was one of the cables just feeding a 2nd lamp?
The three core may have gone to a daylight sensor with the two core probably the supply. To be honest they don't appear to be in good condition the casing for the choke is cracked.
Ill give it a try when i get home, ill also get a closer picture.The three core may have gone to a daylight sensor with the two core probably the supply. To be honest they don't appear to be in good condition the casing for the choke is cracked.
Not so sure it is a 3core, think someone has bodged it and sleeved the cpc black!The three core may have gone to a daylight sensor
Possibly but cable is different as it has a brown core, the supply cable being black (live) and blue (neutral). There idea appear although difficult to see two bare cpcs within the fitting.Not so sure it is a 3core, think someone has bodged it and sleeved the cpc black!
All the twin and earth we use has a brown core!as it has a brown core,
He is in Italy not the UK. Italy I believe used black as line and blue for neutral.All the twin and earth we use has a brown core!
Difficult to tell on a small phone screen but where cable is stripped, it looks oval(ish) like a T&E cable.
Quite frankly it looks junk, the sort of thing we'd throw in a skip in an instant! Especially with more efficient LED alternatives available.
Yes, didn't notice his location to start with!He is in Italy not the UK. Italy I believe used black as line and blue for neutral.
Reply to Problems installing lights in the Lighting Forum area at ElectriciansForums.net
