L
Leesparkykent
11 houses right on the beach... was a joy to come to this site when the weather was good.
Reactions: 3 people
Be a bit of both , salt water will cause verdigris, but so does acidic plaster /lime. Then the reaction starts..................
Plagiarised this.
Copper(II) acetate is soluble in alcohol and water and slightly soluble in ether and glycerol. It melts at 115 °C (239 °F) and decomposes at 240 °C (464 °F). It can be prepared by reacting copper(II) oxide, CuO, or copper(II) carbonate, CuCO[SUB]3[/SUB], with acetic acid, CH[SUB]3[/SUB]COOH.
Verdigris is a variable chemical mixture of compounds, complexes and water. The primary components are copper salts of acetate, carbonate, chloride, formate, hydroxide and sulfate. The secondary components are other metallic salts, acids (organic and mineral), atmospheric gases and water. All the components are in an ever-changing and complex electrochemical reaction equilibrium that is dependent on the ambient environment.
Reactions: 1 person
Very nice. Similar to a job I done many years ago, in London behind Highgate cemetery.
Did about a weeks work on Canna about 7 months ago. Not bad views from there on a good day!
Reactions: 4 people
Not on a job, between jobs. Suppose there is worse places to live!
Reactions: 2 people
View from the I've just completed.
Electrician Talk
Thread Tags
Tags Tags
completed
Leesparkykent,
Resu,
