OP
Guest55
LED lenser H7 is on my future tool aquisitions list
Discuss What tool next in the Electrical Tools and Products area at ElectriciansForums.net
This is your next priority purchase! It's more than decent enough to get you started:
Draper 34704 300 mm Combination Square: Amazon.co.uk: DIY & Tools
I do have a pro one but it is probably my most used hand tool along side my screw drivers and snips. It is used all day every day!
Nope, no analogy, no inuendo, I mean literally folding paper. It seems pretty accurate, but that's just why I hate it I think, it's not precisely accurate! I'm OCD like that lol
If your're doing Domestic a good lump hammer (wickes with the grey fibreglass handle is cheap and easy to use a lot of other makes are more like a short stick with a brick on the end) and a scutch chisel found at most wholesalers or building supplies.
or if Commercial /Industrial
a good quality Hacksaw and set of box spanners or normal spanners would be a good start
(ps the combination square for those who don't know has a steel rule and you use one of the attachments at a time, one is a centre finder ,a set square and a protractor)
The harder the metal,, i.e. steel, the smaller the tooth pitch. Softer metal needs less tooth pitch, otherwise the swarf clogs the blade upif you get a hacksaw go for 24tpi blades, if you go for 32tpi it takes forever to cut unistrut
Reply to What tool next in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
