G
Geordie Spark
Right I'm away to a job, enjoy the (recurring and almost certainly circular) debate guys.
https://www.youtube.com/watch?v=aZdPCCKPDBY
Already been mentioned mate, better materials or design for the terminations.
Fike have designed a smoke bomb capsule for just this type of fire. Sadly it can not be installed in domestic properties. A domestic CU in the cupboard under the stairs full with coats and other combustible items, a smoke detector could save lifes and property.
So mains powered, interlinked smokes in houses, 1 near the CU and more elese where would be a better, policy IMHO.
Its not just CU's that catch fire in homes.
No they aren't, the regulation makes no mention of containing a fire it only requires that the box itself does not catch fire.
There is a big difference between being non combustible and being able to contain a fire!
You've got to now accept that any reports/statistics coming from any of the interested parties that support the metal only stand, are going to be totally biased towards that end, you'll not be getting any real facts about the alternatives or those materials that conform to current fire retardant BS/EN Standards....
Well not until they start having to backtrack or do the about turns because they haven't originally thought everything through. Knee Jerk reactions generally throw up all sorts of unforeseen problems, that cause other knee Jerk reactions, and so it goes on!! It used to be called ''Management By Crisis'' and it tends to get to be a very expensive exercise when left to it's own devices....
I really like that idea. Make it a reg on all new builds/rewires and CU changes to have a smoke detector within 3m of the CU. Easy and cheap.
Its still not solving the problem of poorly manufactured CU's and idiots installing them.
You might as well invent a small capsule that you fit inside the CU's that breaks under heat. The capsule fills the CU with foam... Problem solved...
Although, as I understand it, a CU is still allowed to have IP2X holes in the sides and bottom. Bit of a poor fire barrier!
I hear you but reading the report I think the concern is also that in a domestic setting CUs are usually found under stairs and near front doors so generally a fire there would impede escape.
The report specifically mentions the difference in CU that even with standard MCBs and no grommets still contain a fire quite well.
People trust us as electricians to give sound advice. Why can't we trust the fire brigade to give equally good advice?
This reg is not for stopping fires spreading completely but just to slow them down. Once the occupants are out - job done.
This is a life saving measure.
Nowhere does it state metal only DBs.
Maybe, but you don't have to be a Phd to understand that is the overall intension of the CU amendment!!
I disagree. I think there will be loads of non-metallic CUs coming out before Jan.
Of course you disagree, but then you change your mind with the wind!! At the beginning of this thread you couldn't agree more with the change to metal CU/DB's!!!
Again you are mistaken. I have never mentioned metal CUs. I said non-combustible. Why are you obsessed with metal? There are other materials that can still meet this new amendment. So I have not changed my mind at all. I fully support the change and always have and it will make zero difference to my day to day activities as an electrician.
I'm not mistaken at all!! We already have non-combustible plastic CU's, it's just they won't now tell you the manufactures, Tell me, why would they be testing non fire retardant CU's in the first place FFS for added effect for the promotion of metal CU's maybe? The article that so impressed you,was promoting the use of metal based CU's, NOT fire retardant Plastic CU's!!!
Come on chaps, wants the point keep having these threads about Amendment 3 Consumer Units. You never gonna agree. What you have to accept is the new reg will be implemented next January. Three manufactures have already produced their efforts, and they are steel. The market for CU's is I expect small. How often do domestic properties have their CU's replaced? It's not like the iPhone market, so why would any manufacturer spend time, and more importantly their money developing a non steel CU. Note 1 says 'ferrous metal, e.g. steel', so why would they bother (and risk) manufacturing anything else.
I suspect the CU market is quite large, as there must still be millions of Wylex/MEM 3036 fuse boards out there, and why the sheds have been making a killing on twin RCD fully loaded CU's for a good few years now....
What risk is that?? The same manufacturers are supplying the rest of Europe with plastic CU/DB's. The market in Europe is many, many times greater than that of the UK!! They don't seem to be having any problems with fire retardant plastic enclosures...
There's loads of 3036 boards out there, but people don't seem to want to spend their money on replacing them. They'll spend 10k on a new kitchen, but fall over when you give them a price for a new CU etc, and the old 'I can get a new fuse board from B&Q for £50'.
Take your point about the rest of Europe, but we are not in the rest of Europe, reg 421.1.201 is specific to the UK. So if BS7671 says, i.e. note 1 ferrous metal, e.g. steel, who is going to make it out of anything else. BS 7671 might not be statutory, but if anybody gets it wrong, your 'Michael Mansfield's QC's' will quote it word for word.
Don't doubt your argument, just think your wasting your breath.
On an end note I have to replace a faulty RCBO today / tomorrow which i bought from Demans a few months ago, (keeps randomly tripping,) all at my cost.
Was going to look at earth leakage testing gizmo, but TBH didn't know much about them.
I don't know how electricians these days can get by without a leakage clamp meter. As for you saying you ''don't know much about them'', leaves a lot to be desired....
I dont have a earth leakage clamp meter,and dont intend buying one. Most EL is down to a low IR to earth,which I can verify with an IR tester. Failing that I can ramp test an RCD on load and off,if there's a difference with the RCD operating at a substantially lower current on load then there's leakage to earth. Unless I'm missing something here?If so enlighten me and I'll buy one. (On second thoughts I've managed for 35 years) !
They are very useful for Comercial/industrial applications.
Cheers
