Discuss Should I use 1mm or 1.5mm earth in domestic lighthing? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Either will be fine as long as it's green/yellow wiring or sleeved that colour.
The earth in the 2.5 is actually 1.5, but 1.5 will be better than 1mm. If you use 2.5mm that may be too big to fit in the switch earth terminal
Hi,
I need to earth a replacement faceplate to a steel back box in the wall.
Should I use a 1mm, or 1.5mm sleeved cable for the job?
What size are the lighting circuit conductors L,N and cpc? written yesterday and forgot to post
please strip the cable correctly using an electricians knife, dont just pull the earth to split the grey sheathing
Please don’t tell me we are still reverting to the “ your going to stress the copper conductor, therefor decreases CSA, therefore an immediate fire risk.” o_O
I strip it like that, not one of my jobs has ever went wrong
These little touches are the difference between an electrician and craftsman.
I am going to disagree.
I still cut a neat edge with my knife at the end of the cable.
If you connect 10 sockets on a RFC and connected them both ways. I bet the resistance of the cpc ring is the same. A lot of rubbish. My college didn’t even bother telling us otherwise.
Reply to Should I use 1mm or 1.5mm earth in domestic lighthing? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
