Discuss Should I use 1mm or 1.5mm earth in domestic lighthing? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Either will be fine as long as it's green/yellow wiring or sleeved that colour.
The earth in the 2.5 is actually 1.5, but 1.5 will be better than 1mm. If you use 2.5mm that may be too big to fit in the switch earth terminal
Seems you might be safer leaving it alone.I just want to be safe.
a metal one.What sort of accessory is it.
please strip the cable correctly using an electricians knife, dont just pull the earth to split the grey sheathing[/QUOTE]
...Or you'll be no better than 65% of all the sparks i've ever met
I thought it was a copper rip cord - what else could it be used forplease strip the cable correctly using an electricians knife, dont just pull the earth to split the grey sheathing
What size are the lighting circuit conductors L,N and cpc? written yesterday and forgot to postHi,
I need to earth a replacement faceplate to a steel back box in the wall.
Should I use a 1mm, or 1.5mm sleeved cable for the job?
These little touches are the difference between an electrician and craftsman.ever went wrong
To be really controversial the training centre here taught to strip it by pulling the cpc! I really don't see the problem with it.My college didn’t even bother telling us otherwise.
Trying to get your knife in a small accessory box is a pain.
Never sI don’t see a problem with doing it with a knife. I just think it’s a faff and more risk of catching the cables. Trying to get your knife in a small accessory box is a pain.
Don't think you would go wrong with a knife like thisTry a smaller knife. These are really solid, unlike the plastic ones.
https://www.amazon.co.uk/Stanley-9MM-Snap-Blade-Knife/dp/B0001IW5A4
That's all I use, as long as they're kept sharp they are a good knife.Never s
https://www.amazon.co.uk/goods4less...7896736&sr=8-3&keywords=ck+electricians+knife
Might change your mind if you were taught correctly in the first place Middy.
Practice and craftsmanship, maybe?I don’t see a problem with doing it with a knife. I just think it’s a faff and more risk of catching the cables. Trying to get your knife in a small accessory box is a pain.
I have always used either a Klauke or Thomas Betts scoring tool,which whips round the periphery of a circular sheath,with an adjustable depth,swivelling cutter. A couple of spins,and then pull off the end,results in the sheath coming off like an onion skin.Just as a matter of interest @PEG how do you strip the outer sheath of SWA without the aid of a sharp implement?
Reply to Should I use 1mm or 1.5mm earth in domestic lighthing? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
