Discuss How to rewire a table saw in the The Welcome Forum area at ElectriciansForums.net
Ok will do cheers ,that's the motor stripped, found the other wire, both are red so which one is live or does it matter?
Live in Airdrie Scotland if anyone close by
If there is no body close who can help, do you know of any Motor Rewind firms nearby, that could be your best bet, shouldn't be expensive.
If altering the saw to 45 degrees causes the cable to pull out, it suggests the cable is too short.
Anyway, if you connect up the two wire and the saw goes backwards, you just dismantle again and swap them round.
Do we know what type of motor this is?
If not,he may get alternate results :)
Yes, I do.
Please explain how a line-neutral reverse would make it spin the other way.
Simples.
If you reverse the line and neutral before the capacitor, there will be no change in direction.
If you reverse the line and neutral after the capacitor there will be a change in direction.
Can you tell from the pictures whether the two wires that have come apart are before or after the capacitor?
Yes, it's outside the tool initially...
Reply to How to rewire a table saw in the The Welcome Forum area at ElectriciansForums.net
