I
Ianmac1966
OK we have a kitchen that had 2 lights in, also 2 light switches. A single and a double switch.
I took the 2 lights out. And above the table put 3 hanging lights and in the ceiling I put recess lights. The single light works the recess lights and the double works the down lights and recess.
Here's my problem. The double switch works perfect. Provided the single switch is on. If it's off depending what the recess lights are doing whether on or off. If there off I can't turn them off if there on I can't turn them off. The way it's wired from the double it goes into the loft in and out each recess light and into the wiring for the old light. I think that's where the problem is. Any ideas where I'm going wrong.
Cheers for the help
Cheers for the help
