H
Hristov93
Hello, i am struggling with something. First of all my name is Yani Hristov, i am 27 years old and I am from Bulgaria. I am working as a production operative, but i want to work something similar to the degree I have from Bulgaria its bachelor's in electronics engineering. So I've started courses in national vocational qualification in electrical installations level 2 including wiring regulations latest edition, inspection and testing too. I gave my degree to naric to compare it to the UK education system and I'm waiting. Basically I want to work in CCTV and fire alarm installations, but can do with domestic wiring too. My point is can i find a job as a mate atleast with those certificates and with the degree from naric to get in the industry? I have 3 years of engineering experience in my country, repaired domestic appliances, installed air conditions, fixed mobile phones, laptops and PCs. Can read wiring diagrams, schematic drawings and technical information. Have full UK driving license, knowledge in use of power tools and measuring equipment. Thank you very much!
Sounds like you are over qualified for a humble electrician job. Why aren't you aiming higher with those qualification? Maybe working for a DNO might be more suited with your skills. I think @julie has or did do that sort of work maybe she might advise you more on such a route. Also it might be helpful to indicate what region of the UK you are in and/or where you could travel to???
As above, I would take advantage of your degree in electronics to be honest, rather than aiming at installing CCTV cameras.
I'm located in Doncaster, South Yorkshire. Well, I don't know really mate, when I came i started to ask in colleges, ring on them and started to read around forums, and as I understood I needed to get and UK qualification, because most people wrote that most of the employers don't care if you have a degree from abroad.
[automerge]1598474533[/automerge]
I just need to start from somewhere because as I read most of the employers don't look good at
I want to start as a mate, because to get i the industry here in the UK. That's why mate.
F
Electricians Jobs
findajob.dwp.gov.uk
F
Trainee electrician, electrician mate
UK
Hristov93,
Hristov93,
