- Reaction score
- 5,398
You said to me.......well some joke......I said some do some don’t......Just confused..
Discuss Bedroom lights without earths in the UK Electrical Forum area at ElectriciansForums.net
Now I understand. That makes sense. I had some dreadful wetpants. Ha I shall remember that. They were wet peasants ahh ha hawetpants are plumbers
wetpsnts, is that text talk for wet peasants? if so I think it is a bit non PC!!!!
Noooooo not Wetpeasants!....wetpants......they certainly ain’t peasants the money they charge ? although I’d love to be there when you jokingly call one a peasant whilst he’s attempting to save ya house ?Now I understand. That makes sense. I had some dreadful wetpants. Ha I shall remember that. They were wet peasants ahh ha ha
Will they accept the report. Or would they need to retest? I think it might prove more expensive and time confusing
The majority of plumbers I have had have been fine though as you say they charge high prices. But I had some lousy ones and it makes sense that in the absolute mayhem they created that they managed to screw up the clampNoooooo not Wetpeasants!....wetpants......they certainly ain’t peasants the money they charge ? although I’d love to be there when you jokingly call one a peasant whilst he’s attempting to save ya house ?
Hence our endearing term (honestly) of wetpants......I’ve no idea what they call us although my tame wetpants genuinely believes that electricity is all “ white magic” ?The majority of plumbers I have had have been fine though as you say they charge high prices. But I had some lousy ones and it makes sense that in the absolute mayhem they created that they managed to screw up the clamp
"black magic" matter too!!Hence our endearing term (honestly) of wetpants......I’ve no idea what they call us although my tame wetpants genuinely believes that electricity is all “ white magic” ?
What are roofers. Is this Northern terminology. I am in CornwallYes mate bad ones ? kevs are kitchen fitters and builders are.......you know! ??
But I will need the report with details of everything being okay. I have to give this to the tenantsI've come across several landlords that have paid for an EICR to be done, only to be told that there is a lot of remedial work before it is issued. In a couple of cases, the report was not even drafted, and half the tests not actually done. I would be suspicious of being asked to pay for remedial work before you can have a copy of the report.
Once you have the report, you can decide whether to use the original electrician or someone else to rectify the issues. You should not have to pay to have a second complete report done.
That made me laugh mate ????"black magic" matter too!!
As a carpenter originally I point out to em that they are just failed carpenters....as historically roofing was a chippies job......they generally through slates etc at me at that point ?What are roofers. Is this Northern terminology. I am in Cornwall
Not correct,But I will need the report with details of everything being okay. I have to give this to the tenants
Is a plastic rose attached to the ceiling okay or does it need to be a light fitting with the bulb enclosed? My problem is it will be problematic to access the loft.411.3.1.1
A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a lampholder having no exposed-conductive-parts and suspended from such a point
Right. My prob is about them accessing the loft which is choker..So a).trying to understand the regs and b) how best to comply..The 18th edition happened..
Thank you that's helpfulNot correct,
you need to provide the Tennant’s with a report
That is now a legal requirement
If there are dangerous faults listed in the report, you have to get work or further investigation started on that within a month.
So if the electrician is withholding the report, it is there fault that you have no report for the Tennant’s, you have paid for it, you should receive it.
James I amThank you that's helpful
It's not so much the key as I do have it, it's just identifying it. It's more the case that the loft is absolutely choker with stuff. Choker.Surely at some point you will need to get in the loft. And if the key is lost then why not get the sparky, or a local handyman(when he is there securing the trunking), to fit a new lock?
I wouldn't knackered the chances of getting a safe electrical system for the sake of a lost loft hatch key.
I’m getting concerned with what’s up there now! ??James I am
That's not great, is the loft space designed to take the weight of it being full of stuff? It's not normal for a rented property to have the loft filled with the landlords stuff.It's not so much the key as I do have it, it's just identifying it. It's more the case that the loft is absolutely choker with stuff. Choker.
Reply to Bedroom lights without earths in the UK Electrical Forum area at ElectriciansForums.net
