Dr Denis
I let out a flat and had an EICR, carried out, to meet the new Private Rented Sector Regulations. The EICR has recorded a “C2” for an extension lead on a washing machine.
The lead supplied with the washing machine is about 1 metre shorter than is convenient for fitting the drainage tube back into the drain, when moving the appliance in and out from under the kitchen worktop. I have fitted a short extension lead between the appliance plug and the 3-pin socket. The extension lead is adequately rated at 13amps and is tucked away such that it is not a trip hazard nor exposed to any risk of mechanical damage. The EICR received, states: “Trailing lead feeds washing machine, Classification Code C2”
I have queried this for two reasons:
1. The trailing lead is not part of the fixed wiring and is therefore outside of the scope of the EICR, which I requested, i.e. to meet the requirements in the Private Renting Regulations.
2. The extension lead is not being used in an unsafe manner and does not merit a “C2”
The Contractor say an extension lead on a washing machine is unsafe and therefore a C2. What comments?
