adonis2
31
47
93
41
Essex
What cable would you use to connect this light through a cavity wall to a FCU the other side of the wall?
I am thinking, 1.5mm² 3 Core NYY-J Cable,
or 1.5mm² 3 Core Rubber Flex.
The light that is being replaced has twin and earth as it has choc box connectors which won't work on the new light.
it is protected by an RCBO on the board.20230502_133218.jpg20230502_133115.jpg
Thanks Dusty, that was my thought to use flex.
By the way, do you see how rough they have left them cables, and they fell out of the connector when I undid the gland nut.
Loosk like they stripped the cable with their teeth and probably did up the connection screws with the back of a tea spoon
The stranded wire should not have been tinned if it was used with screw terminals. It should have been ferruled or left bare. Tinned wires will become loose over time.
Reactions: freddo and Avo Mk8
I'd suggest 1.0mm flex - then no one can argue that it doesn't comply with BS7671.
If you can, a tube, or conduit, is good to protect it within the cavity wall.
I wish you'd stop giving away trade secrets.
  • Funny
adonis2
Essex
What cable for this outside light
Lighting Forum
adonis2,
telectrix,
