shaw22
Chicago
United States of America
Buzzer wiring to ACROPRINT FT217 Time Clock - see drawings below
Question:
I would like to hookup 7 Buzzers to be driven off from the above single time clock. The buzzer I would like to use is Edward Signals 870P 24V AC or 871P 24V DC
Edwards Signaling - 870P / 871P Series AdaptaHorn Panel Mount Vibrating Horn NEMA Type 4X - https://www.edwards-signals.com/index.cfm?pid=257
(But I can use other low voltage 24V AC or DC buzzers - if you have a recommendation. The buzzer should be able to produce 103db and should be able to reduce the sound through the front panel screw)
Which one - AC or DC 24V is better for a factory environment?
Can this be wired in serial ? or do I have to run individual home runs for each buzzer ?
What is the relay I am going to need ?
The factory size is 200 feet wide x 560 feet long (112,000 Sft). Is there a restriction on the run length to these buzzers from the relay?
870P AC Series
Adjustable output: 78 to 103 dB
400 hour rating at 50% duty cycle
871P DC Series
Adjustable output: 78 to 101 dB
200 hour rating
Thanks for your help!
-Shaw
Question:
870P AC Series
871P DC Series
200 hour rating
-Shaw
I will also need the model of the relay switch that will sit between the time clock and the buzzers.
Chicago
URGENT advise needed - Buzzer wiring to ACROPRINT FT217 Time Clock
shaw22,
shaw22,
