P
pushrod
Thanks for the very detailed reply Chris - must admit i still haven't got my head around it completely - will have to give it a bit of time for it to be assimilated
Take your point and can vaguely remember something about this in the brb or a niceic guide, will have to look when i get a chance.
I must admit i interpreted gn3 differently.
I took the "eg where bonding clamps have been 'built in'. " just to mean that access to the clamps on MPBCs was restricted, ie behind panelling. Definitely see that you could be quite correct though.
Those IEE guys should get someone on board from the Plain English Campaign!
GN3 is referring to where say the structural steel is used as a bonding conductor for example and can not be removed, testing between two points the resistance should be no more than 0.05.
