S
spicler08
Hi, any help or advice on this would be greatly appreciated...
In my kitchen I'd like to fit some some new downlights under the top cupboards and an LED strip on top of the cupboards. I also already have existing kitchen spotlights in the ceiling. So that's 3 lots of lights (hope you're with me so far!...). All of which I'd like to be connected to a single 3 gang dimmer switch on the wall. (See image attached).
Now I know this can be done but I'd really appreciate any advice on the best way to do it. One of my concerns is the LED strip, which is 10 meters in length and pulls around 50 watts - however, they only seem to come with a 12v transformer for plugging into the wall (like a laptop power supply). So what can I use instead of this to wire them up to the mains? Do I need an LED driver? All of the LED drivers I've seen are only 12-16 watts max load so I can't see how I'm going to connect a 50 watt strip to a single LED driver if the maximum load is 12-16 watts? What am I missing here? Do I need an LED driver or is there an alternative?
With regard to the downlights, I think I've got this right - I need 5 lights, each 20w, so therefore I need a 100w 12v transformer? See link below for the one I think I need. Please can you confirm if this will be suitable.
Please see images and links below for a better idea of what I'm trying to achieve. Like I say - any help, advice or alternatives would be greatly appreciated...
Many thanks
Steve
LEDs - Click here for link
Downlights - Click here for link
Downlights transformer - Click here for link
Not really because if you'd read my previous comment in this thread you'd see that I've already stated that I'm not doing it myself, plus none of the links I posted are for B&Q, plus this is a question about kitchen LEDs and downlights - not garden lights. So no - it's nothing like that.
I was referring to one of your original posts on the forum where you got free information on your garden lights and subsequently posted that you'd been down B & Q and done it yourself.
This is the "Electricians forum" and as such is for people in the industry to share information. You may not have found my "guidance" helpful but I think you fall under the DIYer heading and as such my suggestion is that you consult an electrician was a sound suggestion.
Some of the people here who offer great advice in posts are often complaining about the lack of work for them.
Reactions: 2 people
...my suggestion is that you consult an electrician...
Consult an electrician - good idea. If only there was some sort of online electricians forum where I could do that...??
...I think you fall under the DIYer heading...
Hmm, I thought 'DIY' stood for Do It Yourself, and as previously stated in this thread, I'm not doing this myself. Do you not understand how I'm saying that because you don't seem to grasp it.
So the lack of work for them is a direct consequence of people like me asking a few questions about what lights, sockets and switches to buy for my kitchen? Even though I've stated several times that I'll be getting an electrician in to do the work. Maybe the lack of work for these "people" is because they spend too much time sitting at a computer on an electricians forum complaining and being a busybody jobsworth instead of doing something more productive and proactive.
If you don't want to help someone who posts a question, then don't - simple as that. But equally, if you don't have anything helpful to contribute or you don't know the answers to their questions, then don't clog up their post with stupid, mundane comments, like ridiculing someone because they shop in B&Q. Grow up.
There are actually people on here that are willing to give 2 minutes of their time to help someone out and offer a few pointers where they can. Kind, decent, generous people - and these are the people I'm aiming my original question at. Several people who fall under this category have already replied in this thread and provided good helpful advice, and I'm very grateful for their time. Anyone else who'd like to contribute additional constructive advice is more than welcome and their help is very much appreciated. Busybody jobsworths need not apply.
be carefull, knock off and lock off and prove it is dead and not you
So effectively this is a light switch that controls a plug socket? Is that what you're saying? If so I like it - it's a great alternative to the FCU. Thanks mate.
"Spicler08" as you have found this is a very "Politically correct" place
and nobody likes answering questions, try to ignore
As for your scenario, you will have to source a dimmable LED driver (which you can buy)
If i were the electrician, id take a permanent supply from the existing celing lights down to the switch, and a three core and earth cable to the top of the kitchen units, three core cable terminated into a junction box on top of the unit, with 2 switch line connections, a common neutral and a common earth
Led driver (L) connection wired into JB with the brown core, underunit lights wired into JB with black core(sleeved with brown), neutrals connected together
Quite a easy job to complete, maybe some patching required depending on whether the floor above could be lifted and whether or not the switch wall is stud/hollow
Had it been me, id upgrade the backbox in the wall for a deeper one or chase in a 2g one
If i were the electrician, id take a permanent supply from the existing celing lights down to the switch, and a three core cable to the top of the kitchen units, three core cable terminated into a junction box on top of the unit, with 2 switch line connections, a common neutral and a common earth
Now that's what I call a definitively clear, concise and extremely helpful answer. Top man - just what I was looking for.
It just goes to show that there are some really decent people on here that will give up their spare time to help someone out where they can. Thanks mate - I appreciate it. Thanks to everyone else as well who chipped in with some words of advice here and there. It's made the job a lot easier now that I can get my head round the nuts and bolts of it.
Help with lighting if you'd be so kind...
Australia
spicler08,
spicler08,
