Currently reading:
Tell us about your faults!
Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
Door entry system seemed to work ok but now getting lots of feedback from one plot it's ok when disconnected from phone and have checked phone in different plot seems ok cables test out ok not sure where to go next
- - - Updated - - -
Apologies in advance if this has been brought up earlier but I'm not trolling through god knows how many previous posts:)
I thought I'd mention a 3 phase fault I had recently for the benefit of a lot of guys on here who are learning or are not familiar with working on 3 phase systems.
See if you can work out the fault. ( if you know it please give the guys a chance to try and work it out first.......ta).
The factory where I work has its own 500kva transformer.
Built in the early 60's this supplied both the factory and the remote office block.
I recently had the DNO run a 3 phase/N SWA cable into the office block so I now have 2 separate supplies.
I then installed a 3 phase board and ran several single phase sub mains to various c/units around the office block.
From the main board I then ran a 3 phase 'dedicated supply' to the server room for the IT dept ( this is the only 3 phase board in the building apart from the incomer).
I was called to the IT dept because the main server had 'crashed'. UPS had kicked in but lots of things not working.
Main thing I noticed on my way there was ALL the power and lighting in the offices was still on.
Anyway...........work this out if you can:)
Testing the 3 phase D/B in the server room gave me these results.
L1-N = 230v.
L2-N =230v.
L3-N =230v.
L1-E = 230v.
L2-E = 230v.
L3-E = 230v.
N-E = 0v.
L1-L2 = 432v.
L1-L3 = 432v.
L2-L3 = 0v.
What fault could cause this, bearing in mind, ALL power and lighting was still on !
I'll wait and see if there's much interest before giving any clues if their needed but I'm sure many have come across this problem on here just thought it would be good to share with others that haven't.
Found this in my mates bathroom ceiling.
The cieling is a flat roof with approx 100m space above the plasterboard , which is also PACKED with insulation.
was it one phase blown and then back feeds through the neutrals indicting a phase present when testing all phases to earth?
L1-N = 230v.
L2-N =230v.
L3-N =230v.
L1-E = 230v.
L2-E = 230v.
L3-E = 230v.
N-E = 0v.
L1-L2 = 432v.
L1-L3 = 432v.
L2-L3 = 0v.
Come on alan dood.....need to know now ....
us thicko's that add extra sockets for grannies extra heater are dumbfounded ...lol
ok.
You were close originally mate so here's one last clue to see if you can fathom it out.
Always better if you work it out yourself:)
The fault caused me to lose a phase.........call it L3.........but all my single phases were testing 230v and non of my circuit breakers on site were tripped?
Twas a head scratcher for a few minutes lol
ok anyone know what the fault was here's your big chance lol
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
