Search the forum,
Discuss Options for bathroom fan in downstairs flat in the UK Electrical Forum area at ElectriciansForums.net
Steve T
Hi all,
Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and 'finished'. Due to the window in the bathroom, it is impossible to get a fan directly out of the one external wall. A window fan is a theoretical option but getting wiring to it would be very disruptive. The best solution I've been able to come up with is a fan which vents through to the next room and then out of an external wall there, where is space for a 110mm hole. The point I'd appreciate some suggestions on is what fan system to install. My only options for power are from the bathroom downlights or a socket on the other side of the wall. However from the downlights I can only get a switched live and neutral, the JB is inaccessible (I don't even know where it is). This leaves me with two options as I see it, firstly a fan that just comes on with bathroom lights, not ideal as there will be no ovverun. The other option is a humidistat fan, powered from the socket.
We need strong extraction in the bathroom, because the flat gets a lot of condensation and generally can get quite humid, no doubt in part due to lack of proper bathroom ventilation, so a powerful bathroom fan should help a lot, at least to fully clear the bathroom. So I'm thinking can you get a remote humidity sensor that can be in Zone 1 in the bathroom and use a powerful inline fan in a cupboard in the next room? I doubt a typical axial fan (with a humidistat) would be powerful enough.
Thoughts appreciated please!
Cheers
I recommend the Manrose Humidistat timer: Humidity Sensors for fans - https://www.tlc-direct.co.uk/Manufacturers/Manrose/Ventilation_Accessories_2/index.html
And this axial fan, very quiet comparatively and powerful: 4"/100mm In Line Duct Extractor Fan - Silent 250m3/hr | Soler_&_Palau (5211360600) - https://www.tlc-direct.co.uk/Products/SLTD250SILENT.html I have both in our en-suite, can't hear the fan when in the bedroom and by the time you have finished wiping down the shower I'm dry for the fan.
Reply to Options for bathroom fan in downstairs flat in the UK Electrical Forum area at ElectriciansForums.net
