Deleted member 26818
You are not the only member there.LOL. And you think that enhances your argument? Let's be honest - that forum is largely inhabited by the clueless and the clinically insane.
Discuss Attaching 13A plug on 20A appliance safety in the DIY Electrical Advice area at ElectriciansForums.net
True though.You are not the only member there.
"LoL - Diversity in action - or possible small overloads of long duration, depending on your viewpointthe IET Forum
where is that stated? Manufacturer data sheet or some BSI or similar document? Thanks.I believe that the maximum flex size for a 13amp plug top is 1.5mm
BS 1363where is that stated? Manufacturer data sheet or some BSI or similar document? Thanks.
If the 13A plug will fit the cable, then there should be no problem.
It’s only when you start welding thicker material that you’ll find the fuse blowing.
Exactly why I only mentioned the alternatives, but it is probably a good idea to state they are a bad idea. I don't believe that there is a risk of the wiring catching fire: the socket will be fed by 2.5mm, and the lead is 4mm, so a 13A fuse will blow well before either of these melts. The precautions against fire were for the benefit of a first-time welder, who may be so concerned about the fuse blowing that they forget the second main danger is from sparks setting fire to the place. (The main danger being electrocution by simultaneous contact with work-piece and feed).Powder extinguishers make a right mess.
Reply to Attaching 13A plug on 20A appliance safety in the DIY Electrical Advice area at ElectriciansForums.net
