Hi everyone,
Looking for a bit of advice please. I am just returning to the industry after a significant absence so forgive my ignorance.
I have just been to quote for a disabled customer who has a battery operated bath lift.
The power pack is detachable for charging, but has become to heavy for him to lift.
the charger voltage is 27V and the charger is double insulated. He wanted me to put a socket outlet in the hall so he could trail the charger into his bathroom and charge the battery up without removing it from the lift assembly.
I was thinking of mounting the charger in the loft with a pull cord switch to control it and having the 27V charger lead come from the ceiling to the lift assembly.
I am concerned that the 'wandering lead' may breach regs. can anyone offer advice please ???????
Regards Lippy
Presumably this is positioned either next to or under the bath?
If your charger is in the loft with the cable presumably in trunking running down to the battery, assuming the cable in the loft to the bath is running 27v, I'd say its ok but I'd have to read my OSG to confirm.
Sounds like a good idea, maybe you could relocate battery to loft also?
i would think that as long as the charger is removed from the bathroom at bath time, there's no problem with your original idea - socket outside bathroom and connect charger when required. talk about nanny state.
Also if I unerstand you correctly, I would ask the manufacturers if the batteries can be charged in situe', some systems require removal to be charged and as yours already does that I would confirm it can be charged as you intend.
Thanks for the response, the battery pack hangs on the lift and has to be plugged into the motor unit, so can not be charged without unplugging from the motor unit.
I was more concerned about the clients elderly wife tripping over the cables. I agree, sometimes H&S can go a bit too far, but such a fall could have serious consequences for aged people. I would just like to do the best job possible.
I don't have your answer I'm afraid but I'm interested to know if the UK bathroom special location regs and zones apply to ELV cabling and equipment.
in the sense that they are more "relaxed" for systems not exceeding 12v , then yes , this equipment is allowed in the more onerous locations.
Why do they limit to 12v when the generally accepted ceiling for touch voltage is 50v?
because the regs assume , correctly , that you would be stood in water with bare feet , thus lowering the bodys resistance considerably , therefore requiring an even lower voltage deemed safer for wet locations.
Merseyside
Battery operated equipment in bathroom
lippy,
Guest55,
