J
John-SJW
A friend may put his house on the market. He had a new CU fitted 8-10 years ago. Double RCDs. An earth cable goes from the incoming supply to the CU. The CU is under the stairs. I noticed that the gas outlet pipe is bonded to an adjacent water pipe that disappears under the floor in a cupboard opposite. That is it. Anyone have any comments on this.
So do any of the bonding cables on the pipe go back to the CU?
Reactions: Baddegg
When you say looked did you islolate and remove the cover of the CU ?
Or are you saying there is simply a short link between the water and gas pipe ?
More detail would be good. It's a bit of a drip feed this one.
A quick check with a wander lead could at least tell you if it is well-bonded to the MET, even if it won't reveal the CCC of the bonding.
No need to test. Looking is enough. What I described was where the earth cables went to and from.
What exactly is the question then? Sorry if I've missed something.
yes there is need. how else do you know if the gas and water are bonded back to the CU/MET?
Reactions: pc1966
Well I have none.
Reactions: DPG
No real question. Just comments of the validity fo the installation.
How can people can comment on the validity of the installation with scant information, some pics may help we do not have crystal balls.
Reactions: DPG
I agree with Westward's comment about our balls.
  • Funny
Reactions: DPG
Thread closed. @John-SJW if you want this reopened contact a member of staff to give them reason enough to reopen it.
  • Agree
Reactions: Timbo
Email
Time zone
Last seen
Earth bonding
John-SJW,
westward10,
