ElectriciansOnCall are a Kent's premier and most accredited electrical contractor covering all CT and ME postcode areas. From changing a faulty light switch to a complete rewire we have the knowledge and experience to ensure that it all runs smoothly. We are fully approved by the NICEIC, and as such you can be sure that all electrical works undertaken are of the highest standard.
We are fully registered under part P of the building regulations to carry out work within a domestic environment, and fully able to carry out electrical installation work within a commercial or industrial setting.
24 Hour Callout Service
We are fault finding specialists, with 5 local offices throughout our working area we are normally able to reach you within 2 hours, 24 hours a day. We offer a complete round the clock callout service with no call out charges, we charge a fixed price based upon a half hourly rate which you are informed of prior to sending the engineer. No hidden extras and no additional costs. We operate 7 days a week 24 hours a day and can usually be with you within 2 hours. We don't use call centres or out of hours companies, when you call your local number you will be speaking directly to the engineer on call for your area. The only time you will get an answerphone message is if the engineer for that area is on the phone or out of signal area, just leave a message and they will return your call. They will be happy to offer free advice where required, arrange an appointment for a free quotation or offer you an immediate response for an electrical fault.
All our staff are fully employed, uniformed and insured. We are proud to be members of the United Kingdom Trades Confederation and fully approved by NICEIC for compliance of Part P of the Building Regulations. We are proud to be Kent's premier and most accredited electrical contractors and will always try to exceed your expectations. Not all electricians are the same.
Domestic
Your consumer unit should look like this:
A. Main Switch
B. Miniature Circuit Breakers (MCBs)
C Residual Current Device (RCD)
If you don't have one of these devices fitted you could be at risk of electric shock.
Since the turn of the century when we first started to use electricity in our homes, the amount of electrically powered equipment we use day to day has steadily increased. Unfortunately, this increase in demand requires an upgrade of the electrical system and all too often domestic installations are poorly designed, installed and maintained.
BS7671 (Requirements for Electrical Installations) recommends that domestic installations are inspected every 10 years to ensure compliance with the regulations and that installations are safe to use / fit for purpose. The consumer unit (Fuseboard) should be clearly labelled and should also display inspection stickers showing the last inspection and date of the next inspection. Socket outlets which might reasonably be expected to supply portable equipment outdoors must also be protected by a 30mA RCD in order to prevent electric shock to users. This also applies to all cables buried in walls below a depth of 50mm.
Commercial
From initial design stage to final commissioning we can tailor a package to suit each individual client. We currently advise and install for a number of leading high street retailers, they trust us to make the right recommendations and decisions regarding their electrical installations. In some cases we have created complete new concepts including mood lighting within customer areas to bespoke lighting within private pool complexes. The range of our experience allows us to make informed decisions based on the needs and specifications of the client.
We offer an exceptional after care package individually suited to each customer and budget, coupled with the fact that we offer a 24 hour, 7 day a week service leaves our clients in no doubt that should the worst happen they can be comfortable in the knowledge that an engineer can be dispatched same day to rectify the problem.
We also offer a fantastic package for residential and care homes that includes a regular periodic inspection , full portable appliance testing and round the clock cover for total peace of mind. We are capable of designing, installing, testing and commissioning emergency lighting and fire detection systems in all commercial premises and can include the periodic testing of these items for your existing installation if required.
Industrial
From rewiring of small machinery controls to complete factory design and rewire we can offer you the experience and knowledge you need.
Switchgear and control gear make up a good proportion of any industrial installation, regular inspection and testing is critical in order to avoid down time and costly delays in manufacture should this equipment fail.
We are happy to discuss all aspects of your electrical installation, regular testing and inspection, pre - emptive remedial or emergency service work. Please call us arrange a no obligation discussion with your requirements.
Visit our website: www.eletriciansoncall.com
Domestic
A. Main Switch
Commercial
Industrial
